i know..this has been ran into the ground..350x swing arm on 300ex
Old Dec 22, 2000 | 12:39 PM
94DGblaster's Avatar
I can't find the threads on this so i figured i'd start a new one.
now, i want to use a 350x swing arm on my 300ex.
What type of axle and carrier can i use? i want a +2 or +4 axle.
I don't know if they still make 350x axles and stuff like that
also someone said you have to space it out. someone that has done this..tell me how you went about this?
how much of a space is there?
thanks all
Old Dec 23, 2000 | 12:18 AM
tprender's Avatar
I did this on my 250x, which is the same as a 300ex. You must us the complet rearend from the 350x; swingarm, axle,shock,bearing carrier, etc. I tried putting the 250 bearing carrier into the 350 swingarm and it was not the correct length to get the big snap ring on. The spacers that you will need is to fill in on the axle bolt. The 350 swingarm on the front is about 3/4 in narrower. Use some washers to fill in on the bolt to take up the space between the swingarm and the frame. Make sure when you are finished that the two sprokets are lined up straight or you will have chain problems. The other problem that I had when doing this was the bolt and the diameter of the hole on top of the shock are different sizes. After doing this the quad was alot more stable on landing from jumps and just plane riding. Hope that this helps you out.
Old Dec 23, 2000 | 03:05 PM
thanks thats all i needed to know
now i just need to decide..blow the 800 on handling stuff
half on motor mods...and half on the handling stuff...400 won't get me much..the 350x back end..and thats it
fd24
Jan 16, 2019 08:59 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
