honda rubicon 500
Old Apr 11, 2007 | 12:29 PM
hillbilly458's Avatar
Default honda rubicon 500
THIS HAS 600 MILES ON IT,ALWAYS KEEP THIS IN KEPT IN ALL THE TIME,WENT OUT TO START THIS AND IT WILL NOT FIRE AT ALL.CHECKED THE KILL SWITCH FUSES AND PULLED OUT THE PLUG AND THERES NO FIRE AT ALL.WHAT CAN THIS BE,?THIS IS REALLY TROBLING,I SEE THERES A DIOIDE IN THE FUSE BOX WHAT DOES THAT DO?THIS HAS TO BE SOMETHING SIMPLE I HOPE,tHANKS
Old Apr 11, 2007 | 01:11 PM
JRM's Avatar
JRM
try useing the primer on the side of the carb, take the right side black cover off and you will see a black **** on the carb- push it 3-4 times and crank the engine over at 1/16th throttle. This usally gets my rubi fired ultra quick.
If this fails to work, then its possabbly flooded- take the spark plug out (after blowing dirt out of the area) and crank the engine over for 10 seconds at full throttle with both the fuel pedcock and ignition turned off. replace spark plug and try to start the engine normally without choke.
* I cant wait for EFI on the new rubicon II whenever honda makes one
Old Apr 11, 2007 | 01:15 PM
JRM's Avatar
JRM
I just read your post again, you said no spark at all? I would check:
1. Right side handbrake, mine has a switch in there and it doesnt like to start when pulled in
2. water in the left handlebar mounted kill switch?
Electrical problems do normally sufrace when the machine is new- then once fixed are very very rare
Old Apr 11, 2007 | 02:07 PM
is there a way to by pass the kill switch or how do you tell if it bad?
wendal
May 9, 2024 09:29 PM
rgjackson
Sep 17, 2015 11:21 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
stcspiderman
Sep 13, 2015 05:15 PM
Jason Campbell
Sep 7, 2015 02:25 PM
