sporty went swimming
Old Apr 14, 2007 | 09:19 AM
onesavage's Avatar
Default sporty went swimming
well this sucks.. i was ride around the edge of a pond and yep she went in .. it was over my head and cold i am up here in michigan.. it ended up floating upside down.. well i guess i was needing a full fluid change anyways..lol..lol.after drining the crb bowl and gastank along withe the air box and clutch cover that were both full.. i got it to fire but only idle soo i called good last night.. i know i can use moblie 1 for oil and a napa oil filter can i use anything else for the frt diff and trans... firts time i have locked this thing i hope i did not hurt it too bad... oh ya i had to pull the plug and man did it shoot ot water..i DID NOT attemp to start it after it locked until i pulled the plug.. ant help would be great...
Old Apr 14, 2007 | 11:23 AM
Indyguy's Avatar
Was it running when it went under? If so you may want to call your insurance company.
If not insured, I hope that your connecting rods not tweaked from sucking in water.
Change all the fluids with the OE stuff (I'd do the engine again after you get it running. The front differential oil has to be the right stuff or the clutches will not work right. Be sure to get all the gas out of the tank and dose the new gas with alcohol gas treatment.
Old Apr 14, 2007 | 11:45 AM
onesavage's Avatar
no insureance its been totaled one already
Old Apr 14, 2007 | 11:58 AM
TLC's Avatar
TLC
Does your bike have a drain plug on bottom of the pipe's back baffle? You may want to drain that. Also drain the pull starter housing and belt housing. For the rest I would just use this sites search option and see what the procedure's are since this kind of thing happens to many people. You do not have to just check the Polaris forum because what has to be done will go for any make of bike.
Old Apr 14, 2007 | 02:30 PM
onesavage's Avatar
well i got it running after draining everything ,gas ,oil,airbox, andthe clutch houseing... seems to run ok, i let it idle until the fan came on.. i have changed the oil twice and still have some water in it.. i have not changed the trans or the frt diff fluid yet.. thats a tomorrow project and i have to get more eng oil..
Old Apr 14, 2007 | 10:36 PM
trailbound's Avatar
been there savage hope it works out for you. Never floated mine upside down though. I think sten just posted some alternative ffor front diff fluid from mobil. Rear diff would probably just be 80-90w.
HYS
Aug 18, 2015 12:28 PM
BigCatDriver
Jan 30, 2001 01:05 PM
leel
Sep 17, 2000 01:34 AM
leel
Sep 15, 2000 07:49 PM
sinurgy
Apr 28, 2000 02:33 AM
