2002 scrambler 4x4.. need help
Old Apr 14, 2007 | 06:18 PM
LilPmpn4x4's Avatar
Default 2002 scrambler 4x4.. need help
my 2002 scrambler will not engage into 4x4... i tried to override the main switch but that didnt work... and when i put 12 volts directly to the hubs they do engage, so i know its not them... is there a fuse or relay that i should replace.. where would it be located..
anyu one have any other hints.. as i ran out of ideas short of ripping the whole thing apart..
Thanks
Old Apr 15, 2007 | 10:13 AM
ftwflh's Avatar
Sounds like a bad switch(the older ones needs to awd light bulb to burn to complete the circit) or wire.
Old Apr 15, 2007 | 11:33 PM
LilPmpn4x4's Avatar
so try changing the light bulb? and that might work is what u are saying?
Old Apr 15, 2007 | 11:41 PM
ftwflh's Avatar
Yes try it and see.
95wolv
Sep 27, 2024 12:00 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
