Improvements for 2002?
Old Dec 23, 2000 | 03:57 PM
OffRder15's Avatar
What do you guys think Polaris should improve/add/upgrade for their 2002 line up?
Magnum HO?
Magnum 335? (9 more cc's to make it a little faster than a golf cart?)
Just wonderin. (Im bored right now cause I can't go ridin! I'm positive you all know how it feels!)
Old Dec 23, 2000 | 04:42 PM
Templar16's Avatar
I think they should make the explorers and trail bosses shaft driven. Also maybe a high/low gear range for all of their quads, and a bigger carb might help the 325 engines 31 mm seems a little small.
Old Dec 23, 2000 | 09:49 PM
Lurch77's Avatar
Reduce the weight on the sport models, along with the small bore utility models. I think the weight of the big bore utility models is fine.
Old Dec 23, 2000 | 10:20 PM
bowtiepu's Avatar
make a sprotsman 500 or(700?) with a 6 spd semi auto..id be in line
Old Dec 24, 2000 | 01:07 AM
Traildog's Avatar
Put the Sportsman on a diet and loose 100 lb. This mod would improve steering effort and acceleration too.
Old Dec 24, 2000 | 08:42 AM
wntgrowup's Avatar
ok,ill have to stick to what i know.
regarding the sp500's.
#1 lighten this thing up,alum,wheels,alloy susp. components etc.
#2 adj front springs
#3 split brakes
#4 improve the way seat att to bike ie rubbers wear off,seat to cab rubber grommet was deleted sometime after 95 mine has been on three bikes now
#5 delete hbar mounted headlight and fill front bump with high wattage piaa type light
#6 design locking device for rear anti sway bar.the problem is that when rear rack and elk meet bikes ground clearance is non existant
#7 last but oh so important more power!!!
2000 sp500
2200 mi
76 bmw r90s
Old Dec 24, 2000 | 09:42 AM
SWAC1's Avatar
I could write a book/wish list for Polaris for Christmas day. But mainly considering my 2000 SP and comments I have for it are,
1. Fuel gauge on gas cap, or wherever
2. Easier access to oil reservoir and coolant bottle.
3. Beefier cv joints in the front steering suspension.
4. Re-engineer the front bumper/rack mounting bolts
5. A tunable clutch, so I don't have to keep shopping around for another modified one.
6. Please let there be a twin on the Sportsman, us power hungry riders need our fix.
Merry Christmas fellow riders, and let it be a safe and happy one.
Old Dec 24, 2000 | 01:30 PM
Templar16's Avatar
Oh yea another thing would be the ability to turn on all 3 lights on the Sportsmans and the Magnum 500.
Old Dec 24, 2000 | 01:37 PM
OffRder15's Avatar
Since the Scrambler is truely more of a TRAIL BIKE, then I think a low range on the tranny wouldn't hurt too much.
Old Dec 24, 2000 | 01:53 PM
SWAC1's Avatar
If they don't, check out Woodsmans posts from a ways back, he solved that one. If not, just buy yourself a set of off road lights and light up the woods!
