air filter
Old Apr 25, 2007 | 01:48 PM
jimmyjohn's Avatar
Default air filter
I have a Rubicon and have been cleaning my stock airfilter in the correct manner. I now have two questions. I have read that it is recommended to apply a bit of high temperature grease on the portion of the filter that meets with the airbox. What I do not know is if this applies to my machine since I tighten the filter down with a O-ring? Also, I have read about pre-filters being used with K&N filters. Can you use them on a foam filter? Thanks guys!!
Old Apr 25, 2007 | 02:06 PM
2004Rancher350's Avatar
Default air filter
I never greased it either on my rancher and never had a problem. As far as the pre filter over the foam filter, I wouldn't. It would be a little more restrictive than stock.
Old Apr 25, 2007 | 02:22 PM
jimmyjohn's Avatar
Default air filter
As far as being a little more restrictive, do you mean pertaining to the power that the ATV can develop with restriced airflow? What I am getting at is I am not concerned about going fast. In fact, I do not go over 20-25mph ever. My Rubicon is a workhorse. So I was thinking that for the added protection it might be worth it. Or could the restricted airflow lead to greater problems inside the engine?
Old Apr 25, 2007 | 02:30 PM
scottphillips88's Avatar
Default air filter
Don't waste your time putting a cover on a stock air filter. Save yourself some time and buy a K&N. Not to mention you are going to get a little more power. Once you have a K&N you can buy a "recharge" kit to keep it clean. Find one on rockymountainatv.com. They are pretty darn cheap even with shipping.
Old Apr 25, 2007 | 03:33 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Default air filter
I agree that there is no need in a pre-filter on a stock air filter. When someone speaks of restricting airflow this will drop hp at all ranges. Its not a good idea to restrict to much or open up to much without doing some mods.
Pre-filters are mainly used with the paper style filters such as K&N to catch stuff that the K&N won't. I don't agree with scottphillips88 and the K&N filter. K&N will allow better airflow and give you a little extra horse but if this is a farm atv theres a good chance you kick up dust that will get through the K&N that won't get through the stock or other foam style filters.
As always to each his own. This is my opinion.
Old Apr 25, 2007 | 03:52 PM
ocean's Avatar
Default air filter
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
