Check Belt light procedures
Old Apr 26, 2007 | 03:01 PM
minnesotaco's Avatar
Default Check Belt light procedures
Can anyone tell me what the check belt light procedures are for a Prairie 360 4x4 ??
I know it has something to do woth crossing wires, but I don't which wires, and from what to what....
Thanks a bunch....... minnesota co
Old Apr 26, 2007 | 10:39 PM
tencubed's Avatar
Being retired is a hoot!
Hmmm. Surprised no one has answered this.
To get this information and a lot of other good stuff visit Nyrocs website at atv.dnsalis.com and look around a little.
Old Apr 27, 2007 | 01:13 PM
alwaysride's Avatar
under the gear lever there is a black and grey connector(also another one of the same coler that wont work). swith the black and gray. also, take apart the little 2 pin connector that is black found coming from the cvt cover. After that is done, turn the key on for 10 secs to watch it blink. THen put everything back in order.
Old Apr 27, 2007 | 01:54 PM
Scott3710's Avatar
Here it is..
Check belt light reset procedure
1. Turn key switch to off position
2. Disconnect the failure indicator switch at the two-pin connector above CVT cover.
3. Disconnect both sets of 5 pin connectors (1 grey and 1 black). It?s between CVT cover and below shift lever.
4. Cross-connect these 5 pin connectors. Connect grey to black then black to grey.
5. Turn key to on position
6. The belt warning light should flash at ? second intervals. Let it flash for 7-10seconds.
7. After letting it flash watch the indicator light while turning the key to the off position. It should flash 3times to confirm memory has cleared.
8. Reconnect everything normally and when you turn the key back on the light should be out.
Scott
Sorry someone already posted.. oh well
bzdok1234
30
Feb 23, 2016 01:55 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
