How Can I
Old Apr 30, 2007 | 06:29 PM
RedRubi's Avatar
Default How Can I
Unsubscribe to all topics. It keeps flooding my Email box and I have to delete and unsubscribe to every one individually. Is there a way to kill this problem?
Old Apr 30, 2007 | 07:45 PM
HeftyLefty's Avatar
Default How Can I
If using Windows Outlook Express you can use the Block Sender Rule.
Open Outlook Express.
Click the message you want to block.
Click the Message Toolbar at the top of the screen and click Block Sender. Click OK to verify.
Outlook Express will add the Sender address to its Block Sender list.
Do this once for every address you want to block and Outlook Express will block all messages from that address until you tell it not to.
To restore a blocked address, open Outlook Express and click Tools-Message Rules-Blocked Senders List. Remove the ones you want to restore.
Hope this helps.
Hefty Lefty
Old May 1, 2007 | 12:45 AM
RedRubi's Avatar
Default How Can I
Thanks. I did that on my PC at work, but they didn't stop coming. I blocked them several times to no avail. There must be a place on this site to unsubscribe to all of them at once, but I haven't found it yet.
Old May 1, 2007 | 01:41 AM
HeftyLefty's Avatar
Default How Can I
Recon,
Login-open Profile-under Profile Visibility; remove the check from the box. This will stop email notifications being sent to you when someone replies to your posts.
If that doesn't work, notify the Admins of this site. moderators@atvconnections.com.
Hefty
Old May 1, 2007 | 01:10 PM
RedRubi's Avatar
Default How Can I
Thanks HeftyLefy, I did that. I'll see if it works. I also put (Unchecked) in the other klittle box whatever that means.
