Help. 300ex running badly on high end.
Old May 3, 2007 | 11:38 AM
Sportax300EX's Avatar
Default Help. 300ex running badly on high end.
I own a 2001 300ex. It starts, it idles, it runs half throttle. When you punch the gas to run it wide open in any gear it starts spitting and spudderin and wants to stall right out. Had the valves adjusted not too long ago, put dry gas in it, had the carb off 2 times and cleaned it.
It runs damn near perfect though when the choke is on wide open.
Need some suggestions please.
Old May 3, 2007 | 12:46 PM
quicksilver's Avatar
it sounds like a plugged main jet. did you spray carb cleaner in all the passages in the carb?
Old May 3, 2007 | 01:23 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
I agree with quicksilver. Sounds like its not getting enough fuel. I think I've read that off timing has these symptoms too. I'd troubleshoot fuel related possibilities first.
Old May 3, 2007 | 04:26 PM
hondabuster's Avatar
Did you remove the lid on the air box?
SOLOLUCKY
Oct 4, 2024 09:09 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
gdmclnh
Jun 13, 2015 05:32 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
