Shift forks... are mine bent???
I noticed my bike finding a false neutral last month at Little Sahara once or twice and then this past weekend it happened four times at Silver Lake... everytime I was riding it hard would go to shift to 5th and it would rev to 9K till I could pull the clutch in, put it into 5th for sure and go. I think it happened once going to 4th too. Is this the shift forks? My quad is an 04 so it should have the updated ones, but then I found this post by MR.HP:
http://forums.atvconnection.com/mess...=shift%20forks
This sucks, I am going have a Silver Lake trip planned in 2 weeks, Allegheny Forest for Memorial Day, and our big trip to St. Anthony 3 weeks after...
[img]i/expressions/face-icon-small-mad.gif[/img]
Eagle, I thought that 03 and newer would have the new style shift forks also but all I have seen is the old style even in 04 bikes. Looks like they are still useing old style in the new motors. When ordering them I have seen 3 different styles of shift forks from Bombardier with the latest being the most beefy. I havent had any problems out of the latest ones with race cut trannys and 125hp.
Generally the shift forks go between 1st and 2nd gear. The forks start to get wear on them then hang-up and don't allow the engagement dogs to fully engage.
So, I'm not sure why this is occuring. . . I guess it could be shift forks, just hate to see you go that far if it isn't.
IF you do go into the engine, I would suggest having the tranny back-cut. Don't want to spend the money going that far and then have the issue again. . . I know it is added cost but, that's just my thoughts. . .
hmm, wonder what would cause this false neutral issue between 4th and 5th...
another question, when this happens it hits 9K rpms pretty quick, I have the Woods cdi so no rev limiter... is this hurting my engine, if so, how much?
I agree with Dune Me. As well when my shift forks started to act up I had trouble getting it into the lower gears, don't believe i had trouble with the higher gears.
If you do go in, get the tranny gears back cut, it makes the tranny shift so nice, I never hit netual or miss a shift anymore.
I know it might seem like a silly thing but have you tried to tighten up the clutch cable a bit and see what that does???
It doesn't like to go in first at all unless I am stopped and sometimes when I try to put it in you can hears some gears rolling.
I have adjusted the clutch cable all over, even re-indexed the clutch arm on the case, more free play, less, not a clutch adjustment issue I don't think. I just put in a new oem clutch and have 60% woods springs. I took the cover off and triple checked, so I know everything is good there. Has to be a tranny issue, just not sure how bad.
I am really worried about the RPM's shooting up, maybe I will pick up a Vortex cdi so I have a rev limiter. I just don't want to put off splitting the cases and then the bike break down the first day in Idaho after a 30 hour drive. That would suck.
i had a similar problem & it ended being the shift shaft was bent REALLY BAD. i thought it was the forks as well. they were fine , i have an 05. just my 2 cents
Also could be your clutch. I know you put 60% springs in there with a new oem clutch, but it could be slipping. I haven't seen any shift fork problems on 04's and later, I think they are not as common. Since it is happening in higher gears, My clutch done the same thing. Even with 60% springs. Just a thought.
