drive sprocket help needed!!!!!
Old May 9, 2007 | 12:20 PM
bill402000's Avatar
Default drive sprocket help needed!!!!!
hi all...im new to the 3 wheeler world...i just bought an older honda big red...and i need your help and advice on a few things....i was told it was the 250 cc size but with no stickers left on the machine i need to be sure....it needs the drive sprocket changed as the teeth are badly wore and letting the chain skip......heres where you all can help........how do i tell what size it is???there are no stickers left on the machine itself....does the engine have the size stamped on it?? and at what location??? and without a repair manual yet i need to know the easiest way to remove the front drive sprocket.....i have removed the high/low range gear box,,,,and it appears the case needs to be removed for the sprocket assembly to be removed......i have seen a pic of the shaft i need replaced but it was for a 200.......will it interchange if this is indeed a 250 cc motor???? if any of you have access to a repair manual and could email me detailed info on removal procedure ide be most greatfull.............im hoping to be riding soon as this will be my first 3 wheeler........had 250 cr dirt bikes so this will be a nice change of pace........thnks all.....Bill ps if you need my email addy just ask.......thnx again
Old May 17, 2007 | 12:14 AM
ThrashAndCrash's Avatar
The engine size is cast into the Jug near the bottom edge. Find the vin on the neck and post the 10th diget that way I can tell you what year it is.
Old May 17, 2007 | 01:06 PM
bill402000's Avatar
if i read all the numbers from the frame correctly its a 17 digit number with the 10th number being a (D) hopefully ill know the year for sure this way and be able to order parts easier....thnx for the help....bill
Old May 17, 2007 | 08:36 PM
"D" is a 1983. And in 1983 the only Big Red was a 200cc........A 1983 ATC 200E
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
cornermike
Jun 3, 2015 07:27 AM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
