2001 Bayou 220 Trouble
Old May 13, 2007 | 10:04 AM
dorrt's Avatar
Default 2001 Bayou 220 Trouble
I need help and wow admitting it is the first step. But the bayou also needs help.Ok i replaced the solenoid,relay and installed a new battery on the atv and the lights indicate it is in neutral BUT it doesnt turn the starter over ,nothing...any ideas what to check next and where to go from here? any help is appreciatedand thanks in advance
Old May 13, 2007 | 12:57 PM
bmj67's Avatar
try to jump the 2 posts on the solenoid with a screwdriver. if it doesnt turn the starter it could be that the starter needs rebuilt or replaced. if it does turn over the check the starter switch on the handelbars
Old May 14, 2007 | 05:47 PM
dorrt's Avatar
Ok after working on the 220 more today I got it to start with the pull start but when i try to use the electrics nothing happens. is there a way to check if its the on/off switch or the startewr button? I have the neutral light on and when i try to start it nothing happens and the light goes out. also tried to cross the solenoid with a screwdriver and I got the same result nothing and the neutral light goes off and doesnt come back on? any ideas or suggestions what to do next? Im disabled and cant pull start it all the time thanks tim
Old May 14, 2007 | 07:34 PM
bmj67's Avatar
to test the starter switch find the black/yellow and black wires comming from the handlebar and use an ohm meter. when the starter button is pushed you should get a reading when you let off it should be infinite. also check the fuse on the starter solenoid
Old May 16, 2007 | 02:01 PM
nevada's Avatar
stupid question.....battery? is it charged?
just b/c its new, doesnt mean it was charged. a new battery only has a light charge, and needs to be fully charged up before using.
Old May 16, 2007 | 02:56 PM
steve243's Avatar
i had the same problem my dad replaced the starter brushes in my 220 bayou now it works fine
Old May 17, 2007 | 10:35 PM
vforcerox's Avatar
hey my son has a 220 bayou as well and we are having the same probs, i am somewhat of a mechanic and i have checked every possible option except the starter, it sounds like that might be it
please let me know if you get yours fixed we are just pull starting his and it SUCKS
thanks
Old May 25, 2007 | 05:59 PM
ToferWatts's Avatar
I have the same problem on my sons 220. I can jump the posts on the solenoid and the starter turns over. I have also checked the starter switch on the handlebars and it is ok too. The voltage is nothing accross the button until it is pressed then it goes thru. but it does not turn over the starter. Any other ideas?
Old May 25, 2007 | 09:11 PM
dorrt's Avatar
Ok i pulled the starter and i used jumper cables and tried to test the starter.i grounded the starter and when i put the power to it the starter turned over very slowly and then on the 2nd and 3rd attempt it did nothing..is the starter junk or am i testing it wrong thanks tim
Old May 25, 2007 | 11:05 PM
bmj67's Avatar
tim sounds like you need to tear the starter apart and give it a good cleaning and check the brushes. i actually just tore mine apart yesterday and cleaned it out beause it was only working sometimes
