Pull Starter for KFX700
Old May 22, 2007 | 10:05 AM
colmac's Avatar
Default Pull Starter for KFX700
Is there a company that makes a mod to add a pull starter to the KFX700?
Thanks,
Colin
Old May 22, 2007 | 11:41 AM
asnowmobiler's Avatar
Just get one from a Prairie,you need the recoil and the bowl shapped gear under it. Everything will bolt right up with no problems.
Old May 22, 2007 | 11:47 AM
colmac's Avatar
wow, great idea, and many thanks.
Old May 23, 2007 | 10:48 PM
Atvstevo1337's Avatar
IF you ever have to use the pullstart the best method is to use it in conjuction with the electric start and it will make your life so much eassyer. even if the batterys dead use it at the same time as your pushing the button for the push start.
Old May 24, 2007 | 09:02 PM
HappywithVForce's Avatar
I can't imagine what it would be like to pull start one!
Old May 25, 2007 | 01:17 PM
It's not that bad,just pull slow and easy till you get to the point were it pulls easier then stop there,let the rope go back in,then pull harder and faster the second time.
Old Jun 2, 2007 | 12:55 PM
colmac's Avatar
asnowmobile please tell me if I am correct, all i need to get is the following...
Here is an exploded view of the parts...
http://houseofmotorcycles.bike...IRIE+700+4X4.asp#stay
49088: STARTER-RECOIL
49080: PULLEY-STARTING
are the bolts all the same size?
And most important, Is that a left hand or right hand threaded Bolt? ( 92150: BOLT,PULLEY) and do i need an impact wrench to remove it?
Thanks, Colin
ghost civic
Jan 15, 2020 07:43 AM
Big bousse
Sep 26, 2015 10:42 AM
ScopeZ_
Jul 28, 2015 01:44 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
