2006 ds650 baja x gearing
well i need help. i have 20'' sand stars and i weigh 235, just wondering what gear combo i should run? iam all stock now.what should i try.
as always thank you so much for all the info already given . it has been i big help to this first ever ds owner.
michaels
michaels
I run a 15/42 and have since I bought my DS. I'm 250 and with a 45 lbs son sitting in my lap- I'm able to climb anything and wheelie for football fields in any gear (including 5th wide open). I would recommend this gearing, but running 20's it will cut your top end a noticible amount. . . .
I droped to a 15 up front & 40 in the rear. found this to be a good all around with nice low end. i can still get 80 mph out of it and with the +6 swinger it will launch super hard in 2nd gear.i tried to go to a 43 in the rear & it was way to low, nice out of the hole but no top end. you may have to change the chain or add to it to go to the larger in the rear. the front is easy to change & cheaper in price. you may want to start there.
cody500ho
14
Aug 14, 2015 05:03 PM
