01 raptor 660
Old May 23, 2007 | 08:43 PM
boooosh's Avatar
Default 01 raptor 660
i put the pully puller on the fly wheel and i cant get it off it keeps pulling the bolts out of the fly wheel where the puller bolts screw in......
any help would be great
thanks
Boooosh
Old May 24, 2007 | 12:44 AM
ThrashAndCrash's Avatar
Done that same thing a few times..........I use a propane tourch right at the end of the flywheel (dont get the crank too hot) while you have quite a bit of pressure on the puller......It comes off with a BIG POP!!!!!!!
Old May 24, 2007 | 05:47 PM
boooosh's Avatar
thanks bro i will give it a try this weekend
Old May 25, 2007 | 10:58 AM
garyc660R's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: boooosh
thanks bro i will give it a try this weekend</end quote></div>
Just wait a minute before you break out the flame. All you need to do is torque up the tension on the flywheel and pop the base of the flywheel a couple of times with a hammer. No need in hitting the flywheel to hard either. If you have enough torque applied the flywheel will jump right off with little drama.....this works. Make sure and have screws long enough to go all the way into the flywheel so you don't rip any more threads out.
Gary
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
