yamaha warrior help PLEASE!!
Old May 26, 2007 | 09:34 PM
RaptorEater650's Avatar
Default yamaha warrior help PLEASE!!
i have a 1994 yamaha warrior . i pretty much changed everything and its all new . when i got the quad it started good . put it puffed blue smoke and then developed a knock . so i got it professionally rebuilt . then it started having weak spark . the guy i bought it off put on a new cdi box . so i thought i should change the igniton coil . still weak spark . then i read about them having stator issues so yesterday i got a new stator and put it on . no spark at all . i dont know what else to check . some wires i need to test somehow?...other warrior issues? . any help would be very greatly appriciated .
Old May 27, 2007 | 03:04 PM
JLsparky7's Avatar
Sounds like you got another bad stator. Did you buy it new or used? I would go with a new stock stator if mine went out. Are you sure you installed ir right?
Old May 27, 2007 | 11:24 PM
i got it to run today . now will idle fine if i just barly touch the gas . but has no power when u rev it . it spiters and sputters but will idle fine?? . the engine is awsome , very strong but mabey the timing i dunno
Old May 28, 2007 | 07:33 PM
lucasislight's Avatar
e brake
2quiker
Mar 22, 2022 08:36 PM
Sep 17, 2015 03:06 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
