clutching probem?
Old Dec 27, 2000 | 12:42 AM
nvmy500's Avatar
I installed a hpd medium performance clutch in my 2000 500 srambler..and i am not shure it helped.. The rpm gets up before it starts to move but does not take off very aggresive..while running at 3or 4 thousand rpm i will let off gas reapply gas and it makes a loud thud from the clutch engaging..Is this normal??Or just out of adjustment? thanks for any help..
Old Dec 27, 2000 | 01:00 AM
SteveXplor's Avatar
When you installed the spring and helix in the drive clutch are you sure you tightened it enough before putting your snap ring in place?If you look at the instructions you got with the kit it will tell you how much to tight it.Good luck
Old Dec 27, 2000 | 12:07 PM
weltmaster's Avatar
steve is right. you have to lay the assembly down with helex toward you and give it 1/4 turd conter clock then push it down then put snap ring in place. my take two people
Old Dec 27, 2000 | 07:08 PM
nvmy500's Avatar
Thanks for responding!! I had a friend help me and he thinks we have it set correctly at 1/4 turn but I am not so shure..I will try it again.Thanks
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
