04 prarie 700 hard to turn
Old May 29, 2007 | 09:14 PM
rockinrodtex's Avatar
Default 04 prarie 700 hard to turn
my 700 is hard to turn. i suspect the strut & strut spring is the possible cause, but there high dollar. so i want to make sure that is the problem. anyone ever had this prob. please help
Old May 30, 2007 | 01:45 PM
cookerwon's Avatar
check to see if your front traction lock is not sticking. jack the front up and turn the wheels you should be able to hold the one front tire from turning
Old Jun 5, 2007 | 03:40 PM
is there an easy fix for the traction lock sticking. i jacked the atv up and both tires spin i cant hold the other
Old Jun 5, 2007 | 08:06 PM
vfrrocks's Avatar
you might want to check the steering stem bushing. they can get dry and dirty and make it hard to turn. a little hard to get to but easy to service, just clean and a little lube,
Old Jun 6, 2007 | 11:57 AM
i've cleaned, greased, it's still hard to turn. when it's jack up it turns real easy
Old Jun 8, 2007 | 11:24 AM
lostOkie2's Avatar
Check/Change your front end oil 10-40W. Has the recall work been done on your steering knuckles?
Quads are hard to turn in 4WD. If your 4WD is not disengaging, then you have 4WD actuator and or 4WD controller problems.
Old Jun 9, 2007 | 08:15 PM
kvfrider's Avatar
What is the recall on the steering knuckles? Where do I find out about it?
Old Jun 11, 2007 | 12:19 AM
FASTFATBOY's Avatar
Change your front diff. oil like lostokie recommended. When you do look any for very small metal fragments in the diff oil. If you have shavings or small flakes then chances are you've blown out your front diff. I've seen it a few times with others bf 650s and a few prairies. I truely hope that your diff lock is just sticking because rebuilding the differential is EXPENSIVE but from my experience a blown out diff sounds like the problem. Sorry maybe yours will be better.
Old Jun 12, 2007 | 11:55 AM
kvfrider call your local dealer. i'm not sure of all the recalls some are just the steering knuckle. some are the the steering knuckle, a-arm. & ball joint. it depends on your model
fastfatboy. i dont think the diff. is blown because i can go into 2 or 4 wheel drive.
Old Jun 22, 2007 | 10:40 PM
wcabadbrute's Avatar
The diff lock could be stuck. Ive had the same problem on my 05 Brute the cable runs $30 easy to change. It would be the actuator because if the bike is in 4WD with it not locked it is still easy to turn thats why it must be the cable.
TheHood
Aug 8, 2015 05:49 PM
ghost civic
Jul 19, 2015 10:13 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
ghost civic
Jul 15, 2015 10:48 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
