Need Help *Ignition
Old Jun 1, 2007 | 03:49 AM
kik's Avatar
kik
Default Need Help *Ignition
In trying to relocate my my key switch today on my '07 400ex I messed something up. When I took apart the housing I accidently grounded out the switch. One spark was let off. When I put it back together to try to start it and make sure it worked correctly it obviously didn't. Question is what blew? a fuse? if so where would it be located? if not that then what could it be?
Old Jun 1, 2007 | 11:02 AM
TommyA300's Avatar
From the positive post of the battery follow the harness 14 gage red wire there is usually an inline fuse pack on that line.
Old Jun 2, 2007 | 11:47 PM
KEv80's Avatar
The same thing happend to my trx450errr. I was rerouting my wires and accidently touched the two wires. It sparked. Didnot think much about it but when I reconnected them I was getting no fire to the starter. on my quad there Is a couple of main fuses that are 15 amps. They are located by the battery. should be an easy fix.
06 trx450er
DG front bumper
MOose nerfs
Pro Taper bars
ITP Holeshots
K&N velocity intake with pre filter
modded air box with lid
jetted
