How should I clean my K&N filter
Old Jun 2, 2007 | 10:22 PM
mbogosia's Avatar
Default How should I clean my K&N filter
Hey guys, what are you doing to clean your K&N filters. I have mine pulled and while it doesn't look dirt and has to have a ton of dust in it from today. Let me know what your cleaning process is.
Thanks
Old Jun 2, 2007 | 11:04 PM
toddmh's Avatar
I use gas,then water..let dry..then coat it with filter oil,work in the filter oil(not so its soaked)then reinstall
Old Jun 2, 2007 | 11:55 PM
mbogosia's Avatar
How about a degreaser cleaner like Krud Kutter. I plan on spraying it with new filter oil so I assume it should be okay.
Old Jun 2, 2007 | 11:59 PM
toddmh's Avatar
that stuff should work just as good as gas,but soak it in water after and let dry before putting on the filter oil
Old Jun 3, 2007 | 12:03 AM
Wolvydude's Avatar
Certain solvents will damage the cotton gauze of the filter. K&N makes a filter cleaning kit specifically because of this...
Old Jun 3, 2007 | 12:15 AM
toddmh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Wolvydude
Certain solvents will damage the cotton gauze of the filter. K&N makes a filter cleaning kit specifically because of this...</end quote></div>
listen to Wolvydude,he knows his stuff..I'm just cheap[img]i/expressions/face-icon-small-smile.gif[/img] plus I dont use K&N
Old Jun 3, 2007 | 02:19 AM
francis03's Avatar
would soaking it in warm water with soap work?
Old Jun 3, 2007 | 10:44 AM
toddmh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: francis03
would soaking it in warm water with soap work?</end quote></div>
not really..you need a solvent of some kind to break down the old filter oil..
Old Jun 3, 2007 | 10:49 AM
bberck's Avatar
Id suggest buying the K&N recharge kit it comes with the cleaner and the oil to service the filter. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 3, 2007 | 12:52 PM
mbogosia's Avatar
Just cleaned it with a light degreaser and water. Worked great. I couldn't believe the dirt that came out. I'm letting it dry and then I am going to oil it up and I'm good to go!
