Gio Hummer 110 Carburetor issue
Old Jun 3, 2007 | 05:56 PM
King Lu's Avatar
Default Gio Hummer 110 Carburetor issue
Hope somebody can help. I just bought the 110 cc Gio mini hummer for my son. After assembling it the fuel line blew off, after I reconnected it I noticed that the fuel flows from the tank to the carburetor and out the over flow drain tube. I can not seem to stop it until the tank is empty. Any ideas on what to do would be greatly appreciated.[img]i/expressions/face-icon-small-frown.gif[/img]
Old Jun 3, 2007 | 06:40 PM
OffRoadNoob's Avatar
Hi King lu,
Is the fuel coming out of the fuel line at the bottom of the carb that is used to drain the fuel from the carb? If so, you probably just need to tighten the screw just above the fuel line. You can open it if you want to drain the carb of fuel. I'm not sure what the "over flow drain tube" is that you are referring to. Maybe you are talking about the carb drain fuel line...
OffRoadNood
Old Jun 3, 2007 | 06:46 PM
King Lu's Avatar
Thanks for the response off road. I did undo and redo the screw above the drain tube, and it still leaked. When I pinched the tube so that no gas would drain out it stalled on me.
Old Jun 3, 2007 | 11:40 PM
Guest
Guest
Posts: n/a
i got a carb that will work on that. i can sell you
pm me ok
Old Jun 5, 2007 | 10:07 PM
King Lu's Avatar
Thanks for the offer, but the guy from all star salez is sending me a replacement carb. In talking to some other people it sounds like an issue with the float not being set properly.
COFatboy
May 2, 2020 12:06 AM
Cummins Driver
Sep 11, 2019 01:22 PM
WesTech
11
Aug 11, 2015 07:55 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Unzzy66
Jul 11, 2015 10:01 PM
