400ex sputters
Old Jun 4, 2007 | 05:01 PM
bullhead85's Avatar
Default 400ex sputters
i put a pipe and the correct jets on a 02 400ex this spring and it ran fine now when it getts in the higher rpm range it falls on its face i figured it was just because the weather got warm but when i changed the jet it only made it worse so i adjusted the valves that wasnt it either any help or suggestions would be great
Old Jun 4, 2007 | 06:44 PM
Fulltiltrider's Avatar
which way did you go on the jetting. need more info
Old Jun 4, 2007 | 09:20 PM
Yagerbomb's Avatar
I would agree with fulltiltrider. we need more info maybe when u jetted and it was fine but then that wether came and lets say for example u started running rich and then u rejet but u jet richer that would just make it worse... u could pssibly try leaning it up some and see if that helps.. just some advice
ReconBayou
Oct 31, 2022 05:37 PM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
