wide open?????????????
Old Jun 4, 2007 | 10:19 PM
jetmotoracer's Avatar
Default wide open?????????????
i haven't gotten all my parts yet but they should be here soon. when i put the 15 tooth sprocket on will i be able to go in 5 gear and run it wide open?????????
Old Jun 4, 2007 | 10:28 PM
pimpsmurf's Avatar
It's 4th gear, and you will probably go faster than you want to. On a 14 tooth, mine gets over 1/2 rpms in 4th gear and I'm 265lbs atm. Mine is still a little toed out, so make sure you fix your alignment in the front before going over 40. It gets dangerous on sandy dirt.
-JNY
Old Jun 5, 2007 | 04:07 PM
oooo so its 4 gear i want to worry about...and if i aline them straight then i dont have equal steering on both sides!!!!
Old Jun 5, 2007 | 06:51 PM
outofline's Avatar
You don't need to worry about 5th gear cus there is no 5th gear! The 250 is a 4speed transmission!
Old Jun 5, 2007 | 06:53 PM
what it says it has 5 gears !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1 they are lying to us?????....you do know i have 07 250
Old Jun 5, 2007 | 08:57 PM
pimpsmurf's Avatar
The "5th gear" is reverse. It's a 4 speed transmission (4 forward gears) with reverse.
-JNY
Old Jun 5, 2007 | 08:59 PM
oooooo... i didnt think of that.. i always thought 5 speed with reverse..oooooo
Old Jun 5, 2007 | 09:09 PM
pimpsmurf's Avatar
Maybe that is why you are having trouble shifting! LMAO
-JNY
Old Jun 5, 2007 | 09:10 PM
lol....no iv only been in 3 gear
Old Jun 5, 2007 | 10:05 PM
pimpsmurf's Avatar
4th gear is WAY higher than the other 3. When you shift from the top of 3rd gear to 4th, the rpms drop to almost idle! Not good for racing, but ok for what we want. With a 14 tooth sprocket and jet kit, the sucker will go fast. probably 50mph. I had a friend with a rancher run with me and he was going 52. He wasn't noticably leaving me behind. I'm going to get one of my RC buddies to clock me with his radar.
-JNY
