Boyou carb leaking
Old Jun 7, 2007 | 10:15 AM
garry.graham's Avatar
Default Boyou carb leaking
I have a 12 black tube that comes from the bottom of the carb. Can anyone tell me or show me where the other end goes. It is leaking gas
Old Jun 7, 2007 | 01:21 PM
Williebee's Avatar
Sound's like the overflow or Carb drain line , if it's leaking the carb drain screw is loose or float is sticking ; or maybe dirt/trash in your carburator causing the problem ! If this is the case you'll have to pull the carb and give it a good cleaning , and install a clear fuel strainer between the gas tank and carburator ; this will catch water/dirt/trash from getting back in the carb ! I would remove the carb bowl and empty the gas into a glass container so you can see if there's anything in the fuel , and after you get this done drain the gas tank if you find any dirt/trash or water in the fuel ; if you find anthing remove the tank empty old gas and flush the tank ! And before you refill the tank with fresh fuel add some Seafoam to the gas tank then fill it up with fresh gas , Seafoam is a fuel cleaner/stabilizer that will keep your gas fresh ; this stuff will keep your entire fuel system clean and also clean's the combustion chamber of carbon deposit's ! You can get the seafoam at most auto parts stores , i get mine from O'Reillys for $5.99 + tax ; price may be more or less according to your location ; and you can get the fuel filter from any small engine repair shop or most auto parts stores ! Hope this help's you get it fixed A.S.A.P. ! williebee
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
