650 prairie Dyna tek cdi?
Old Jun 20, 2007 | 04:23 PM
rehm436's Avatar
Default 650 prairie Dyna tek cdi?
Any one running a Dyna tek cdi box? How much better did the bike run after? And are they worth the $200.00? When I bought the bike it had moose module on it and I took in off and didn't notice any difference.
Old Jun 21, 2007 | 09:51 AM
Crankdog's Avatar
rehm436,
The moose mudule only make a difference when you flog the throttle from 0-3 mph. Under normal riding, you can't tell it is there. The CDI improve the entire rpm band, and does make a noticable difference. It also removes the reverse override, raises the rev limiter (increasing top speed), helps the bike start easier, run cooler, and is definitely worth the money. It is like going from a P 650 to a P 700.
Old Jun 22, 2007 | 08:18 PM
wcabadbrute's Avatar
The moose module is not a complete timing recurve device. It changes timing at the crack of throttle. Dynotech eliminates the reverse overide and eliminates limp mode for the belt system. Well worth the money when combined with other mods.
Old Jun 24, 2007 | 01:08 AM
750reasons's Avatar
I have the Dyna CDI and the bike sputters. I was told that this is a side effect of this CDI. I will say that this bike will get up and go when called for. Rad fan is definitely off more, no reverse limp mode, 100 hour belt rest gone. That engine miss is a **** off though.
Old Jun 24, 2007 | 11:00 AM
Crankdog's Avatar
That engine miss is only on some of the 750's, 650's don't suffer this with a CDI.
Old Jun 25, 2007 | 04:38 PM
iv built 650 and 750 brutes with the dynotech and they both dont sputter. its because the motor is running to lean at half throttle
Old Jun 28, 2007 | 03:31 AM
kawiBF750's Avatar
the 750 has a miss at low speeds there is a bullitin from kawi to rejet
or change the needle and seat in the front carb look into it the dealer does it free
(or the good ones will)
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
PrairieDog126
Sep 12, 2015 05:23 PM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
