250 ex needs bearings how do i do it
Old Jun 20, 2007 | 05:34 PM
tattooman's Avatar
Default 250 ex needs bearings how do i do it
could not figure out where they go in rear toke out axle and need to know how to put them back any pics please send them to me at jasontshearin@yahoo.com
Old Jun 20, 2007 | 06:35 PM
Fulltiltrider's Avatar
They are inside the axle carrier. You will have to pull the carrier out of the swingarm, heat it up a bit with a propane torch and beat the bearings out w/ a hammer and flat punch. Here is a tip for ya. put your new bearings in your freezer for an hour or so before you put them in. They will be much easier to put in when they are cold. GOOD LUCK and welcome to the forums.
Old Jun 20, 2007 | 07:25 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
So you started this project without a service manual??????
Old Jun 21, 2007 | 06:00 PM
bombrider04's Avatar
Before you go putting new bearing and seals in the rear I would inspect the carrier for damage and clean it really good and also inspect your rear sprocket, chain, and front sprocket and if one needs replacing replace them all...Clean out the carrier if it is in good shape.
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
