AT tire help
Old Jun 20, 2007 | 10:43 PM
kurt1011's Avatar
Default AT tire help
My 350 bruin 4x4 needs some new shoes. i ride mainly trails with the occasionaly deep mud hole. looking at bearclaws, mudlites and swamp lites. I am adding itp wheels to get and additional 1" wider offset per wheel. Keeping it stock size 25". Also, weight is a factor for the little 350, the rear wheels weigh: stock ~ 18 lbs, bearclaws 23, mudlites 19.3 and swamplites 23 lbs. i have also read the swamp lites sit taller than the other 2 - this is a negative for me as i am trying to add stability. Suggestions? thanks for the input
Old Jun 21, 2007 | 10:42 AM
SBuckJ's Avatar
Reconranger (automatics are for sissies)!
I had the Mudlites and didn't care for them. I now have the Swamplites and ride pretty much the same as you. They are easier steering and a more comfortable ride than the Mudlites and I haven't lost anything in the mud. Nice comfortable tire all-around. I don't have any experience with the bearclaws.
Try <a target=_blank class=ftalternatingbarlinklarge href="http://www.mudthrowers.com
">http://www.mudthrowers.com
</a>
Hope this helps.
Buck
Old Jun 21, 2007 | 08:33 PM
kurt1011's Avatar
thanks for the input...
Old Jun 21, 2007 | 08:46 PM
buckaroo50's Avatar
Check out either MudCats, or MudGear, both are very good trail tires and work really good in the mud.... 25" MudCats also have 1" tread depth. I run both - MudGear on the front and MudCats on the rear
http://www.tiresunlimited.com/...ang/MudCat/MudCat.htm
http://www.nebraskatire.com/atv/gear/mud_gear.htm
Also a very good tire is Duro Buffalo
http://www.tiresunlimited.com/...V%20TIRES/duro_mud.htm
Old Jun 22, 2007 | 01:39 PM
HeftyLefty's Avatar
Don't overlook Goodyear Mud Runners. They even have a run flat version now.
Old Jun 22, 2007 | 08:00 PM
v2rider's Avatar
I have 1000 miles on my swamplites, and they are my next choice of tire when i need them again. They have NEVER went flat, or not pulled me out of the crap. I vote for swamplites
Old Jun 22, 2007 | 11:45 PM
kurt1011's Avatar
were the swampltes taller than stock tires...assumming same size. i really like this tire and leaning towards buying them
Old Jun 23, 2007 | 07:07 AM
CaptainQuint's Avatar
I wanted something cheap and fairly mild for my old project Polaris I use on the farm and I went with Dirt Devil ATs. I've been pretty happy with them so far. They're pretty good in the mud and pretty good on hardpack and everything else. They seem to be a good all around tire. Not bad in the snow either.
If you ride gravel roads a lot be aware they seem to grab a rock every now and then, hold it and then toss it. I think it gets caught in the tread somewhere. Not a big deal if you have good fender protection. I don't.
Old Jun 23, 2007 | 08:04 AM
v2rider's Avatar
The Swamplites added about 3/4 inch more of ground clearance. That was also a plus for me.
Old Jul 28, 2007 | 06:45 PM
vinson27's Avatar
The 25" ITP Terracross may also fit your needs. They are fairly light weight, ride well and are 6-ply.
