tightening a (too)loose chain
Old Dec 30, 2000 | 11:21 PM
waynaferd's Avatar
I have a 00 TBlazer, and plan on going down 2 teeth on the rear sprocket. My original chain is just about outa adjustment, so I imagine with the smaller rear sprocket there won't be any adjustment left. Now, would it be a good idea to file some of the pins out and remove a few links to take up some slack, or would I be better off buying a new chain? The chain looks and works good, but its all stretched out. Oh, and going down a few teeth on the rear will give me more of a top speed, right? Thanks....
Old Dec 30, 2000 | 11:32 PM
x_scrambler3's Avatar
If the chain is good put the new sproket on an see how many links to take out. If you go down 2 teeth it will incress the top end but also reduce the take off power. I wouldn't suggest it unless you have a aftermarket pipe.
95 TB DG pipe DG nerfs .020 off head 34mm carb 12 front 34 rear 18x9x8 rear tires 22x7x10 fronts Fox rear shock 2000 red scrambler plastic Chain tenstioner Wet weight 265lbs
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bmark0610
Sep 7, 2015 09:42 PM
