Banshee issue ! need help ASAP
Old Jul 19, 2007 | 12:05 AM
Easter's Avatar
Default Banshee issue ! need help ASAP
Hey Iam workin on a banshee in my shop and I cant figure out whats wrong with this thing , i cleaned both carbs , put new fuel and fuel lines on it and the fuel is on and so is the airbox and filter , no intake boots are even cracked , it was running ok when it came here but it would skip and stall out , now it wont even start for me , please help , thanks
Old Jul 19, 2007 | 12:06 AM
Easter's Avatar
also its all stock
Old Jul 19, 2007 | 12:10 AM
YIYO's Avatar
Chek for spark and fuel, if both are present and still no ignition, chek compression.
Old Jul 19, 2007 | 12:12 AM
YIYO's Avatar
Also replace the plugs.
Old Jul 19, 2007 | 12:19 AM
Easter's Avatar
all of it is good , iam stumped
Old Jul 19, 2007 | 03:43 PM
fastquad02blaster's Avatar
If you have spark, fuel, and compression you should be all set. I don't have any clue on this one either. Sorry I couldn't be of any help.
Old Jul 19, 2007 | 05:38 PM
Easter's Avatar
thats cool man i even stump the yamaha techs lol hopfuly this thing gets running soon , thanks for the help
Old Jul 19, 2007 | 05:39 PM
Easter's Avatar
iam thinkin it might be the degree key , i wonder if its striped...ill look into that later
Old Jul 19, 2007 | 09:05 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
check the timing
Old Jul 19, 2007 | 10:01 PM
rruser's Avatar
Did you happen to put the slides in wrong? The carbs are setup where the slides can go in backwords if they are swaped between the carbs. The slides have a edge cut off of one side that should be facing away from the motor when installed right.
