Ball Joints on 2004 Sportsman
Old Jul 22, 2007 | 12:41 PM
sportsman70004's Avatar
Default Ball Joints on 2004 Sportsman
Has anyone ever tackled replacing the ball joints on a Sportsman? Both left and right are bad on my machine. I was wondering if it is as easy as it looks or do you have to take it to the dealer.
Old Jul 22, 2007 | 02:12 PM
onesavage's Avatar
oh stendori!!!!!!!!!!
Old Jul 22, 2007 | 04:10 PM
hc's Avatar
hc
That is what i am doing on my sportsman. To do the ball joint replacement you have to use a specialty tool or make a tool that works.
Try this place for the tool. Polaris ball joint replacement tool
Old Jul 23, 2007 | 05:46 AM
MOUNTAINEERRIDER's Avatar
Just replaced a set on 2004.5 Sportsman 700..Drop a-arm..remove plate (two screws on each) heat strut ..use a good set of vise grips and hammer and it should slide right out..Freeze new ones and heat strut and they will slide right back in...Hope this helps..
Old Jul 23, 2007 | 10:55 PM
woodself's Avatar
I pushed out our 700s by pumping grese into them thru the fitting in the tower.With our 500 the grease was just pushing thru the balljoint so I slid a rubber washer over the stud of the balljoint then followed it by a stack of washers.Tightened the castle nut back on and now the balljoint was sealed so I pumped them full of grease and they pushed out.
STLyamwar
Jul 25, 2020 04:44 AM
COFatboy
May 2, 2020 12:06 AM
velcro7279
Aug 24, 2015 01:15 PM
toonces
Aug 12, 2015 06:42 AM
musselmark
Jul 17, 2015 02:40 PM
