Sportsman 450 bogging and sputtering
Old Jul 22, 2007 | 04:39 PM
Snapshot's Avatar
Default Sportsman 450 bogging and sputtering
Yesterday I washed my quad and cleaned the K&N air filter and replaced the spark plug.This morning I went to go out for a ride and it was bogging and sputtering very badlly. It would run fine on the top end, but hitting the throttle from a dead stop and around corners made it bog out. I checked the new spark plug and it was fouled with black soot, I checked the gap on the plug, I drained the floatbowl for possible water and double checked the throttle freeplay and all are fine. While in neutral it revs fine, but under load is when it happens.
Any ideas as to what the problem might be? My next step is to pull the carb out and check for plugged jets or float bowl adjustments
Old Jul 22, 2007 | 09:25 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you reoil the k&n filter? maybe too much oil?
Old Jul 22, 2007 | 11:02 PM
Snapshot's Avatar
I can rewash the K&N and re-oil it , but I never use a whole lot of oil, becuase I wash it frequently. I will put the stock filter on and see if it is the filter. Thanks!
Old Jul 23, 2007 | 08:25 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did changing back help any?
Old Jul 23, 2007 | 10:35 PM
Snapshot's Avatar
Nope!
Old Jul 23, 2007 | 11:31 PM
NBsportsman's Avatar
Sounds like it's running too rich. Pull the dome off the top of the carb and lift the "C" clip up one notch on the needle then try it and let us know how it works. I'll bet it's hot and humid where you live....
Old Jul 23, 2007 | 11:56 PM
Snapshot's Avatar
Yeah, we have been getting slammed by monsoon in my area and it got pretty humid lately. It will be a couple of days before I can work on it again but I will take your advice and change the needle setting and see what happens, I love my quad but next one is going to be EFI.
Old Jul 24, 2007 | 10:00 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
No E.F.I.......for me.........At least you can work on yours....... 450 with the carb...............What wound you do if you have trouble with your EFI when you get it?.............Caper.........
Old Jul 24, 2007 | 10:16 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i dont think you should have to lift the needle as it wouldnt all suddened start running crappy. hows the air intake and vents all clear and not pinched? just my .02
Old Jul 25, 2007 | 09:53 AM
These things come jetted so rich from the factory that a change in the weather can affect them. My 500 was doing the same thing a few summers ago when the weather got hot and humid and the needle was the fix. I have since dropped two sizes on the main jet and still drop the needle for summer running....
