440EX HEAD PIPE RED HOT
Old Dec 31, 2000 | 09:15 PM
TRX440EX's Avatar
JUST INSTALLED A WHITE BROTHERS E-SERIES PRO MEG EHAUST. STARTED THE QUAD UP AND LET IT IDLE AND THE HEAD PIPES TURNED CHERRY RED IN COLOR. WHEN YOU RIDE THE PIPES COOL DOWN. SHOULD I ADJUST THE CLIP ON THE NEEDLE AND GET A BIGGER PILOT JET OR WHAT IS THE PROBLEM?
Old Dec 31, 2000 | 10:39 PM
hondatrx300ex's Avatar
go a size bigger on the main jet.... and maybe one notch down on the needle....yea down I think to gives it more gas....you're just runnin too lean
Old Dec 31, 2000 | 11:53 PM
TRX440EX's Avatar
THANKS I'LL TRY THAT TOMMORROW. TRX440EX
Old Jan 1, 2001 | 01:25 AM
GrimReaper's Avatar
Changing the main jet and needle position will not cure your lean idle. Put in a 42 pilot jet and you should be alright.
Old Jan 1, 2001 | 11:49 AM
yea thats true...
Old Jan 2, 2001 | 02:32 PM
DEPALMA's Avatar
I HAVE A 300 EX WITH A FMF PIPE I ALSO HAVE IT RE-JETTED BUT THE PIPE STILL GETS HOT, I AM NOT SURE ON THE PIPE YOU HAVE BUT MINE DOES NOT HAVE A HEAT GUARD LIKE TH STOCK PIPE MY RIGHT LEG WOULD HEAT UP AND MELT MY PANTS ON THE PIPE, IT ALSO MELTED MY DAUGHTERS PANTS WHEN I TOOK HER FOR A RIDE BE CAREFUL, I JUST BOUGHT AND AFTERMARKET EXHAUST HEAT SHIELD IT WORKS GREAT (THE COMPANY I BOUGHT IT FROM IS JAMES LUCKY 1-800-233-2637 IT WAS $26 TOTAL GOOD AND SAFE INVESTMENT GOOD LUCK WHATCH THAT PIPE EVEN IF YOU RE-JET IT WILL STILL GET HOT WITH NO HEAT GUARD
2000 HONDA 300 EX
FMF PRO CORE 4
K&N JET KIT AND AIR FILTER
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
greg86hd
Sep 16, 2015 12:32 AM
