Ds650 question????
Old Jul 30, 2007 | 04:52 PM
Tapper1823's Avatar
Default Ds650 question????
I went on a long trail ride on saturday... at the end i was running low on gas and i stopped it died and then i swtched it to res then i tried to start once then nothing like that battery is dead. i hooked the battery up to a charger when i got home and let it charge for a few then did the auto starting option on it and it doesn't do anything turns over a little it any. whats up is the battery toast its a newer one??? also i noticed that my coolant went down alittle is that a bad thing or normal on a long hot ride???
Old Jul 30, 2007 | 11:34 PM
flux's Avatar
could be alot of things....
bad batt connection....
bad starter... or conn. at the starter....
bad conn. on the starter solinoid...... or solinoid...
starter switch....
could be the batt.(charge it and take it somewere and get it tested....)
if the coolent was low, could be getting into the cyl.(bad head gasket)
pull a plug and check for coolent on the plug and in the cyl. ......
pull the plastic plug on the right side of the motor (center one) and
find the right size allen head socket and see if the motor turns over nice.....
hope this helps.....[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 30, 2007 | 11:51 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Good answers flux to test the head gasket or radiator hop over to pep boy's kragen or checkers and rent a balkamp radiator tester it will show you if your loosing presure and where.read the instructions.And this one actualy sounds like a bad cell in the batt but have it tested.then if its good go after all your connections. have fun with it.[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img] EXPLORE j/k.
Old Jul 31, 2007 | 01:16 AM
Tapper1823's Avatar
Its the battery it junk it wont even charge on the charger
Old Aug 1, 2007 | 12:18 AM
AZSAND's Avatar
Glad to hear that while your at putting a new batt in you should go ahead and clean all your connections.especialy the grounds.[img]i/expressions/face-icon-small-wink.gif[/img]
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
