Clunking noise on '07 700 SP
Old Aug 6, 2007 | 02:31 PM
drumdude's Avatar
Default Clunking noise on '07 700 SP
A friend of mine just picked up a new '07 700 Sportsman. He's frustrated by a clunking noise that comes possibly from the u-joint area when the throttle is let-off. The dealership told him it would go away as things broke-in, but he's not satisfied with that answer. Any ideas? thanks.
Old Aug 6, 2007 | 04:42 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
chances are its the normal driveline slop they all have it, and it doesnt really go away. there is backlash noise that you hear when on and off the throttle.
Old Aug 6, 2007 | 05:13 PM
HondaFinn's Avatar
It is normal, I have it on my SP 700 and my neighbor has it on his SP 600. Took me awhile to get used to it also.
Old Aug 6, 2007 | 11:06 PM
tdi's Avatar
tdi
I think the noise can be traced to a loose drive chain inside the gearbox. It will probably get worse as he puts miles on it and the chain stretches. I think that mine has. I know someone that had the chain so loose that it rubbed on the drainplug. The dealership ground the drainplug down to reduce the noise. If you change the oil in the transmission, you can put your finger in the drain hole and feel the slop in the drivechain.
I have also read that the noise is due to something in the EBS. It would be interesting if someone without EBS on a 700 would post their experience with the driveline noise.
Do a search on this forum for "Sportsman Noise" to see just how common this is.
Old Aug 6, 2007 | 11:22 PM
cfwilkins's Avatar
My PoPo does it.....done it from day 1. Not really sure how long this quad will last.....My Yamaha doesn't do it...
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
