Will not start
Old Aug 7, 2007 | 03:58 AM
1funpolaris's Avatar
Default Will not start
I have a 1999 250 2 stroke Trailboss. It has been sitting for 3 years in my garage. I just replaced all of the filters ( air, fuel ect). I drained all the gas and oil out and put in a new battery. It would turn over but would not start. So, I pulled the carb out and cleaned it. It still will not start and now that I got the card back when I try to start it or even pull start it, I can pull 1 or 2 times then it seems to bind up on something!!!! Does anybody have any ideas what I might try next??? Oh, it was not binding up before I removed the starter! Any suggestions would be great.
Old Aug 7, 2007 | 07:19 AM
samk's Avatar
I would try a new plug,,, if you haven't already. And, did you pull the starter drive gear with the starter? If not, that's probably the cause of the binding.
Old Aug 7, 2007 | 07:31 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you check to make it was firing, has good spark and make sure gas was getting thru?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
