Rubicon Brakes leaking
Old Aug 7, 2007 | 10:03 AM
busdriver's Avatar
Default Rubicon Brakes leaking
Did a yearly maintance and found the rt front brakes wet and rusty. My son installed a new wheel bearing seal because it appeared to be bent and cleaned the big rubber seal and re greased it. I had it in the river Saturday just to test it for leaks and it leaked again. I just recleaned it again and seal looks OK. Am I overlooking something. This is a 2002 model and has never been in mud pits but has been threw some big mud holes.
Any advice welcome.
Thanks
Old Aug 9, 2007 | 09:15 AM
HondaTechnician's Avatar
The seals on those brakes are only dust seals, the will never hold water out for long.
Also on those units if it has ever had to have the front wheel bearings replaced due to a failure, take a good look at the axle sealing surface on the axle itself, if you find it pitted it wont hold a seal, and would require the axle to be replaced.
Old Aug 9, 2007 | 10:58 PM
LittleBill's Avatar
did you replace the outer drum seal? thats the biggie, i have found if the brakes have gotten wet, those have to be replaced as the dirt and grim get into the seals and wear them out.
they are designed for water a bit unlike tech above says, i ran every mud hole for 2 years before needing to replace everything in the front
Old Aug 9, 2007 | 11:04 PM
<div class="FTQUOTE"><begin quote>Originally posted by: LittleBill
they are designed for water a bit unlike tech above says</end quote></div>
No sir, you are wrong, they are not meant for water sealing at all.
Honda recomends that the unit never be in more then 4" of water.
Now we all know thats not real world happening, but they are never the less "dust" seals. True water/oil seals are spring loaded to maintain contact with the sealing surface.
Old Aug 11, 2007 | 11:32 AM
MikeM's Avatar
sorry hondatech, but CSA, or coil spring actuated seals are not the only type of liquid seals
3 years, one regrease on the front and still no water in my brakes. Look at Bill's picture and tell me they don't work.
Old Aug 11, 2007 | 07:48 PM
Part number 91261-HN5-671 Dust Seal, FR Brake Price $11.31
Old Aug 11, 2007 | 10:04 PM
MikeM's Avatar
not arguing what they call it, but your simple explanation of seals. the majority of oil/water seals are csa, but not all
Honda recommends many things for warranty, but the fact is they are waterproof if you maintain them properly
not my preference, but they are adequate
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
