New Here and really need some help.
Old Aug 8, 2007 | 12:42 PM
trailman1's Avatar
Default New Here and really need some help.
I have a honda recon and use it for transportation while hunting. The problem I am having is that the shocks max out when I put any substantial weight on the thing especially on the back. What i want to do is try and get a stiffer shock for the back, also probally a set for the front. If I could get a few more inches of lift that would be good also. Any help would be greatly appreciated.
Old Aug 8, 2007 | 01:41 PM
JeffinTD's Avatar
I think highlifter makes a lift kit, but I believe it's a bracket to relocate the shocks and not a set of stiffer springs.
Maybe someone will chime in with a retrofit for parts for some other machine. Otherwise, if you've got the shocks bottomed out with the load, it might be time to consider a bigger machine, if that fits the budget.
Anyway, welcome to the forum.
Old Aug 8, 2007 | 02:22 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I agree that you probably need to step up to a bigger machine. The little Recon is more of a recreational machine than it is a workhorse. Trouble is, when you overload a machine, it can start handling poorly.
I would say as much as possible, distribute the load between the front and back, so the back isn't taking it all.
Old Aug 8, 2007 | 03:19 PM
JeffinTD's Avatar
Another possitility might be a small, light trailer...
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Sassinm1
Sep 30, 2015 04:23 AM
Matt123
Sep 29, 2015 01:29 AM
2many2ride
Sep 27, 2015 04:35 AM
