Best Plow
Hey Vegashunter, I got my plow about a year ago for my 06' 500 EFI. I went with the 52" straight blade. With the 52" if you have stock tires when you angle it all the way to the left or right your wheels are still behind the plow. I've also used the 52" blade for moving dirt, sand, gravel just about anything and have had no problems with anything being bent or twisted. Hope this helps.
when you make up your mind on the plow let us all know what you got and ease of install...dont hesitate to post pics..always help some others with pics--looks and tech . [img]i/expressions/face-icon-small-wink.gif[/img]
I would go with the 60" plow since with the quad being 48" wide the 52" plow would only overhang 2" on each side of the quad, and if its angled you maybe running over the plie of snow you are plowing. plus that extra 8" of plow would help you plow your driveway a lot faster.
Jim
Jim
good deal..where are you located at vegas? do you get THAT much snow every year? would take that into consideration as far as cost..what will work compared to need?...just my .02$ worth
either way by all means keep us posted..
The 52" is still wide enough angled all the way to left or right that your tires aren't runnin over any unplowed snow. I had the stock tires on mine for half the winter pushin snow with the 52" blade and had no problems tramping unplowed snow or anything like it with it angled. However, if you are plannin on put different tires you may want the extra 8". I put bigger tires on my quad and now i can't angle all the way over without tramping snow, because of the wider tires.
If you plan on using the blade for moving dirt,sand,gravel I wouldn't go any bigger than 52". The 60" may get to much stress put on it and may end bending and breaking parts moving dirt and sand with 60" blade.
kampswas
Sep 23, 2015 05:05 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
