Swisher Dump as a plow?
Old Aug 8, 2007 | 04:37 PM
Rockhauler's Avatar
Default Swisher Dump as a plow?
I was just wondering if the dump bucket could serve as a plow for a small area. I know its narrower than a typical plow so it'll take longer.
We have a small gravel driveway so I would never be scraping down to the pavement anyway, and both cars are all wheel drive so I'm mostly concerned with just keeping the snow from building up.
Thanks.
Old Aug 8, 2007 | 06:13 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
should be fine
Old Aug 8, 2007 | 11:25 PM
JohnO's Avatar
You probably could move snow with it, as long as it isn't too deep. Can't angle the bucket, so heavy snow will just mound up in front and you'll end up having to lift, turn and dump a lot.
The snow blade can be angled, which pushes the snow to one side. Drop it and take off.
It's a metal snow blade, so it makes a pretty decent gravel scraper, too.
Old Aug 9, 2007 | 10:05 AM
Rockhauler's Avatar
Thanks for the advice, I may end up getting both in the end.
Old Aug 10, 2007 | 10:35 PM
tencubed's Avatar
Being retired is a hoot!
I have tried using the bucket to move some snow around and it's a poor substitute for the plow at best. Snow build up in the bucket and you end up just pushing a path with the snow pushed to both sides. Once the snow is compacted in the bucket it can be a bear to clean out.
We have both the plow and bucket and would urge you to make the same choice.
Old Aug 11, 2007 | 11:10 AM
Rockhauler's Avatar
Thanks for the advice, I appreciate it.
Old Aug 13, 2007 | 06:19 PM
Reb2's Avatar
I have to agree with tencubed. I have a small tractor that I use to stack the snow with and the bucket is always packed full. Typically I use the ATV to plow the snow back then use the tractor to stack so I don't need as much stock pile area.
shimanok2
Jan 29, 2016 07:37 PM
kampswas
Sep 23, 2015 05:05 AM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
