what octane gas? warrior 350
Old Aug 8, 2007 | 11:34 PM
hummer93516's Avatar
Default what octane gas? warrior 350
I have a 2003 warrior 350 i and currently running 91 octane gas in it and i was wondering if its ok to run 93 octane?
Old Aug 9, 2007 | 02:25 PM
rruser's Avatar
With a stock motor, Yamaha itself says the motor will run off 86 octane. 91 is already more than good enough. If its running good now you won't gain anything by running 93.
Old Aug 9, 2007 | 07:51 PM
Raptor450's Avatar
I have always ran 93 octane in everything I have owned and never had any problems related to gas.
Old Aug 9, 2007 | 09:10 PM
sky852's Avatar
i have octane booster in my gas and im sure its beond 93 octane. mine runs fine. like rruser said its more than enough unless u have a high compression piston.
Old Aug 9, 2007 | 09:49 PM
bigned1904's Avatar
it will never hurt your quad to run to high of a octane it hurts it when you run to low of a octane.
Old Aug 9, 2007 | 10:26 PM
Jasonp's Avatar
you can hurt performance if you run to high of octane gas as well. The burn time will be to long and peak cylinder pressure will be lengthed out cause you to lose power.
Old Aug 9, 2007 | 10:58 PM
bigned1904's Avatar
your right about loss of power jason but it wont damage. the lower the octane the quickier it ignites.
Old Aug 9, 2007 | 11:03 PM
Jasonp's Avatar
yeah, on the warrior it's got such low compression that you would never "damage" it runing 87.
Old Aug 10, 2007 | 04:28 PM
sled05's Avatar
If your manual says to run 87 octane, then use it! The higher the octane the slower the ignition of the burn. High octane is meant for high compression engines. If you were to use 87 octane in a high compression engine, you will experience pre ignition. If you use high octane 91-93 in a low compression engine, you will get a delayed combustion of fuel and it will leave deposits behind and mess up valve seating. And those are the hard facts.
Old Aug 10, 2007 | 08:38 PM
kyledvor61's Avatar
what would you be able to get away with with a 10.5:1 Wiseco?
