warrior tether kill switch
Old Aug 10, 2007 | 11:00 AM
QIKER's Avatar
Default warrior tether kill switch
I rescently bought an 89 warrior and my key ignition is shot.I just bought a 2 wire tether kill switch but the stock keyed ignition is a 4 wire system.I did figure out how to bypass-hotwire the system to get it to turn over and run but I would like to wire the kill switch in for safety and theft deterrent.Can anyone pm or email me the correct way to wire in the kill switch using the stock ignition wires....?Thanks....
Old Aug 10, 2007 | 11:13 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
use the wire on the side opposite the plug wire on the ignition coil.. and run the ground to a place on the frame.. i ran mine to one of the plastic bolts for thefront plastic( 1 of the 2 at the very front of the atv).. really anywhere on the frame would be good and really it's not a theft deterant because all they have to do is pull the gronud wire and it will make the teather killswitch stop working imediately.. that is also why your teather killswtich may stop working randomly on some day.. wire came loose on mine quite often.. until i twisted it around the bolt twice before running it in.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
hueby
Aug 29, 2015 08:34 AM
hueby
Aug 28, 2015 07:26 PM
sweaver
11
Aug 18, 2015 03:47 PM
Hatrackr
Aug 11, 2015 09:03 PM
