HELP!!!
Old Aug 12, 2007 | 11:59 AM
kentiffnmeoh's Avatar
Default HELP!!!
Hey all.. i have a 2000 yamaha warrior... it has no spark... what's going on.... it's been doin this not starting thing for about 2 years.. then just keep trying and it'll start and run for months.. my lucks ran out.. i just put a new carb on and went to start and nuttin... i know somebody know whats up... thanks all..
ken
Old Aug 12, 2007 | 02:30 PM
Raptor450's Avatar
Default HELP!!!
Mine had a similar problem one time. Turned out to be the wiring in the rear that went to the CDI was rubbing the frame just enough to ground out sometimes. It would run fine for a while, then all of a sudden it would die and not start back. I got mad one day when it quit and I kicked it, then it started fine and ran a while, so I knew I had a loose wire or a wire that was shorted out.
Old Aug 12, 2007 | 03:15 PM
Default HELP!!!
ok thanks for that..i went out there and looked at all those wires..they look free and clear an didnt look like they rubbed..could it be that cdi box or coil..??causing no spark..?? thanx again..
Old Aug 12, 2007 | 05:00 PM
Blasterman3315's Avatar
Default HELP!!!
Yeah...you may have a new carburater but did u adjust it right?
Old Aug 12, 2007 | 07:46 PM
Default HELP!!!
yeh but it has NOOOOOO SPARK..............how im gonna adjust the carb.....ona stock warrior...witout NOOOO SPArk......!!!!!!!!!!!
Old Aug 12, 2007 | 08:35 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default HELP!!!
check the stator, pickup coil, ignition, battery charge
Old Aug 15, 2007 | 03:31 AM
HONDA CRUSHER 93's Avatar
Default HELP!!!
i'm having the same problem with mine, and ive checked everything, but the pickup coil. where is it what does it do and how do i know if it's bad?
