Had a little roll over
So Im new to the whole quadding scene. Did a little research and decided that the renegade 800 was what i needed to buy for my first toy. Very nice..i like! Haven't done anything to the bike yet but plan too. Kind of pissed about not being able to mount a winch. Any ideas on when the will have a winch package?Also..what do you guys recomend for tires for the renegade? Before i get anything aftermarket done on the bike i thin i need to get my problems that i have caused straightened out. I havnt got the catwalk down pat yet..although i am getting better. The other week i ended up flat on my back and the quad rolled over. not much damage that i know of except plastic and i busted off my brake lever. And yes this was only after putting 5 hours on the bike. I took it in for its first service and the shop said everything was fine. I now get a bit of a grinding sound sometimes when i use the back brake..Does anyone have any sugestions on why this might be..or what i did to this thing..brake lever is on the way, but i dont want to have it in the shop for too long as summer is coming to and end and it is a 2 month wait for work on a bike where i am from.
The grinding is most likely sand or small rocks in your rear breaks from the roll. Hit the back brakes with a pressure washer, should solve grind issue. If not take them apart and clean them up.
As for the winch, with a welder you can put a winch plate on anything. Find a creative mechanical inclined buddy that can weld up a plate for you.
nth
nth
