Trying to remove rear A-arm on 04 sp700 Help
Old Aug 18, 2007 | 10:20 PM
Motorworld's Avatar
Default Trying to remove rear A-arm on 04 sp700 Help
I bent my A-arm on my 04 SP700 How do you get the lower front bolt out? It hits the axle. Do you remove the axle? Can you loosen the rear diff and raise it enough to get the bolt out? Anybody had this problem? Thanks
Old Aug 19, 2007 | 11:00 PM
Motorworld's Avatar
Has anybody removed the lower rear front A-arm bolt that hits the axle. It seams that the axle should pull out but I don't want to wreck anything.
Old Aug 20, 2007 | 07:46 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
do you mean the balljoint nut?
Old Aug 20, 2007 | 12:24 PM
Motorworld's Avatar
I can't believe that I have the only sportsman that the front bolt that holds the lower rear A-arm to to frame hits the axle when trying to remove it.
Old Aug 20, 2007 | 01:01 PM
outside2day's Avatar
Motorworld, I replaced the lower left rear A-arm on my 04 700. I didn't experience what you are describing. 2 bolts at hub, and 2 bolts at the frame. Nothing was in way when I did this. Ridgerunner.com has new take off parts, might check their prices. Cheaper than what I paid dealer.
Old Aug 20, 2007 | 06:24 PM
Motorworld's Avatar
The head of the bolt is about 1/4 inch away from the cv joint on the axle. their isn't enough room to get the bolt out. Has anybody had this problem?
Old Aug 20, 2007 | 06:48 PM
Motorworld-looked at my 800, think you are talking about the upper rear A-arm. I have not had one off, but see what you are talking about. They should've ran the bolt from other side. Would think someone on here has done this.
Old Aug 20, 2007 | 10:14 PM
Motorworld's Avatar
On my 700 the lower bolt is the one by the axle and you can't turn it around because it will hit the axle with the nut. The axle is that close that the nut won't fit in their only the thin bolt head. Their seams to be a lot of different designs of the rear end. My cv joint is by the differental with a large end where the boot attaches to and the bolt hits that piece. Can I pull out the axle from the differental without to many problems?
Old Aug 20, 2007 | 10:36 PM
NBsportsman's Avatar
I just ran out the the shed to look at my 500 and now I know what you mean mine is the same... As far as pulling the axles some have used slide hammers because just tugging on them sometimes just doesn't cut it....
Old Aug 21, 2007 | 07:35 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it isnt that hard to get the cv axle out if its not that old of a bike. you may have to pry a little as you pull. good snapping motins work on mine. good luck.
