70cc China ATV Brand new NO spark help.
Old Aug 19, 2007 | 11:41 PM
Nice EH's Avatar
Default 70cc China ATV Brand new NO spark help.
I got a brand new 70cc ATV and theres no spark i went over everything and i dont know what to check or do next.
Is there a way to test the ignition coil?
Please help
thanx
Old Aug 23, 2007 | 02:55 AM
HONDA CRUSHER 93's Avatar
i don't know whats wrong with it, but i do know that a lot of china atvs don't work straight out of the crate. good luck with it and welcome to the forums.
Old Aug 23, 2007 | 07:18 PM
SilveradoSS's Avatar
Does it have an alarm system? If so, press the key fob button multiple times to make sure the alarm is disarmed and try again. Also check for loose wires in the ignition circuit. Make sure the kill switch on the handlebars is set to run.
Old Aug 24, 2007 | 10:46 PM
Outof$'s Avatar
I had the same problem with my Kazuma 50. After going through everything I could think of I found the problem in the kill switch on the rear. If yours has this check to see if the connection is releasing all the way back in.
Old Aug 25, 2007 | 10:50 AM
89stp's Avatar
You can check power and ground to the coil. One wire on the coil should be power all the time with all switchs on and the other on should be pulseing to ground with the engine cranking. Let us know if you get it going.
Old Aug 28, 2007 | 07:25 PM
OffRoadNoob's Avatar
Check the safety tether at the back of the quad if it has one of those. If it is a problem, just disconnect the wires going to the tether kill switch at the back of the quad. First, just make sure that the rubber plug is pushing the button all the way in. I remember one day, the rubber plug came loose on mine, the button popped up and stopped the quad. I was quite confused at first, but then figured it out.
Is the starter motor turning over, but just no spark? If so, it could easily just be the safety tether kill switch.
randycraft24c
Aug 5, 2015 02:50 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
