i need help
Old Aug 26, 2007 | 11:40 AM
03400ex's Avatar
Default i need help
i have a 03 400ex it runs good at idle and mid range rpm but at high rpm it starts missing i pulled the plug and it was dark black and dry the olny mods i have are is slip on pipe k&n removed the choke and two holes in the air box
Old Aug 26, 2007 | 12:26 PM
web1666's Avatar
Default i need help
if you got the quad with oil in it drain the oil and put new oil in it
Old Aug 26, 2007 | 07:39 PM
03400ex's Avatar
Default i need help
i just did a oil change not to long ago and the spark plug
Old Aug 27, 2007 | 06:06 AM
HondaTechnician's Avatar
Default i need help
You state that it only misses at hight RPM, either you are hitting the rev limiter or because of your mods, you need to rejet. Im not sure what web1666 was getting at with the oil change, but that wouldnt affect your running.
Old Aug 27, 2007 | 09:17 PM
03400ex's Avatar
Default i need help
thanks for all the help ended up being the outer wear on the k&n fillter was really dirty
