Routine Maintenance Help Kazuma Cougar 250CC
I have a cougar 250cc automatic 2WD liquid cooled. I need a repair manual/maintenance.
I am going to take it up north for some serious long trail rising and I need to change all of the fluids, and lube aeverything up, etc. Need to know where everything is caps, drains, zerks, and what kinds of fluids I need to buy.
Please help.
Thanks!
Please help.
Thanks!
you have a honda cn250 clone engine, 3 places that the oil needs to be changed, one, engine, you can use 10-40w, 15-40w or 20-50w oil, i use rotella 15-40 from wlamart, second place, transmission, need to remove the cvt cover to beable to drain the gear oil, 80-90w here, you will also need a gear oil pump to add the gear oil, and the third is the reverse gear box, also takes 80-90w gear oil, i also buy rotella gear oil from walmart. if you add to much gear oil in the reverse gear box, it will leak, so be careful
Elkaholic
Sep 6, 2015 02:44 PM
