07 KFX90 WIRING(CDI)/NEED HELP!!!!!
Old Sep 10, 2007 | 07:07 PM
AIRMOBILE101's Avatar
Default 07 KFX90 WIRING(CDI)/NEED HELP!!!!!
Man, I needs some serious tech info. To make a long story short , I bought a KFX90 cdi box for my sons 07 KFX50. Well of course it wont work!!!! I spent a lot of research tring to figure this out. Come to figure out that the actual CDI on the KFX50 is a four wire(prong) 12V system(black=hot wire/kill) ,( green=ground), (black/yellow=coil) and (blue/yellow==pulse coil).
Most bikes run a 5- wire configuration w/ a exciter wire from the stator to the CDI box.
Anyways , could someone with a KFX90 2007-2008 MODEL please tell me how many wires enter the CDI box!!! Color code for the wires would be great also. I just need to figure out if the KFX90 is a 4 or 5 wire system.
Also , If anybody knows where to get a 4 wire no rev cdi box, please let me know or any other ideas would be great!!![img]i/expressions/face-icon-small-happy.gif[/img]
Actually, if you are running a four wire cdi box on your bike(regardless of make/model). Please let me know so I can research it. Thanks!!
Old Sep 12, 2007 | 01:39 AM
Sirgrover65's Avatar
I have an 08 Kymco Mongoose 90 which is the same as your KFX 90 with exception of the body, The CDI Box is a 4 wire system. I wouldn't mess with it at all. Theres a lot of junk CDI's that say they work but wont. BEWARE
Old Sep 12, 2007 | 01:55 AM
Yea , I figured it out. I actually have the KFX50. I just wanted to install a Kawi(Kymco) 90 CDI obx for a little more rev. I wont know unitl tomorrow if it increases the RPM or not.
Old Sep 12, 2007 | 01:58 AM
Did You Remove the Speed Rectriction collar? Not sure if thats the exact name, but oh well.
Old Sep 12, 2007 | 02:49 AM
Yep , Removed the collar, re-adjusted the clutch, re did the variator rollers , re -geared the front and rear sprockets. Added a 18MM carb. I thinks its about as fast as its gonna go.
Old Sep 12, 2007 | 02:59 AM
Thats sweet, thats what im starting on, on my sons quad (mongoose90) whats the best way to re-adj. the clutch, after taking and the collar off. I also put on a performance boss drive face. And What company did you go with for sprockets?
Old Sep 12, 2007 | 03:12 AM
<div class="FTQUOTE"><begin quote>Originally posted by: Sirgrover65
Thats sweet, thats what im starting on, on my sons quad (mongoose90) whats the best way to re-adj. the clutch, after taking and the collar off. I also put on a performance boss drive face. And What company did you go with for sprockets?</end quote></div>
Well , I installed 2000RPM clutch springs in the clutch , I wasnt able to change out the main spring because It didnt fit with the original sleeve that keeps it in place. So what does that amount too? The bike moves sooner with less RPM level.
Did you adjust the roller weights when you put the boss on?
Rebelgears.com for ther front sprocket. A bit pricey , but it works. Assuming that the front sprocket is the same as mine, you will need part# 333 when you order.
I got the rear sprocket off ebay. It actually for a Kasea 50/90
Old Sep 12, 2007 | 03:22 AM
No. I didnt adj. them, but now that i know, i should get on that. Is that pretty Straight Forword on how to do that?
Old Sep 12, 2007 | 03:26 AM
Well , I dont exactly mean adjust. Want a mean is did you replace them with heavier or lighter weights? The heavier==== more top end , lighter===== higher revs
Old Sep 12, 2007 | 03:27 AM
Oh, part# 100 for the rear on that sprocket from rebel gears!!!
toonces
Sep 5, 2015 01:14 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
quickwhips
Sep 2, 2015 06:53 AM
frostphase
Aug 19, 2015 07:11 PM
DeFox500
Jul 26, 2015 06:32 PM
