ATV 50/90 not starting
Old Sep 17, 2007 | 01:46 PM
jnar's Avatar
Default ATV 50/90 not starting
Hi all, I have a 10 month old Chinese ATV 90. It ran great until a month ago. It sat for a few months do I drained the gas and charged the battery. The battery would not hold a charge. ( I replaced the battery ) The spark looked weak, so I cleaned the magneto. It then ran great for the weekend. It sat again for a few weeks and now it won't start again.
I have charged the battery and cleaned the carb bowl and put new gas in it. Again looks like a weak spark but I am not sure. I put a shot of ether in it to see if it would turn over, but no luck. Any Ideas?
Old Sep 17, 2007 | 02:25 PM
billl2099's Avatar
have you change the spark plug yet? i'm assuming it a 4 stroke, should take a NGK C7HSA, next do a valve adjustment. then if that doesn't work get back to us
Old Sep 17, 2007 | 02:43 PM
jnar's Avatar
I put the plug in my Honda 50 and had no problem starting it. I will check the valve clearance tonight.
Old Sep 17, 2007 | 03:10 PM
billl2099's Avatar
valve clearance should be .004
Old Sep 24, 2007 | 02:50 PM
jnar's Avatar
If the battery is completely dead and I use a charger to try and start it, would the dead battery keep it from starting? ( not enough spark ? )
Old Sep 24, 2007 | 10:33 PM
SilveradoSS's Avatar
If the battery were shorted internally it might.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
