450R water in tranny oil
Old Sep 17, 2007 | 06:13 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Default 450R water in tranny oil
I am in the process of replacing the water pump seals on my '04 450R.
On the last ride I ended up with water in the tranny. Anyone else have a problem with this?
Old Sep 18, 2007 | 12:52 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
First time I have heard of that one I think. I monitor the dirt bike forums as well for things like this, and don't think I have heard of it before.
Did the oil emulsify? Was it so compromised that you might have done bearing damage or anything like that?
Old Sep 18, 2007 | 10:28 AM
Pirate Biker
Limping Rider!
<div class="FTQUOTE"><begin quote>Originally posted by: reconranger
Did the oil emulsify? Was it so compromised that you might have done bearing damage or anything like that?</end quote></div>
Don't think I did bearing damage. Hopefully not, but yeah, it was like a pink milkshake.
Doesn't take much moisture to do that, though.
I am replacing the clutch.
Old Sep 18, 2007 | 07:38 PM
DBR1990's Avatar
There is an inner and outer waterpump seal. sounds like the inner seal is bad. seen it happen many times. easy fix.
Old Sep 18, 2007 | 07:48 PM
Pirate Biker
Limping Rider!
Yeah, I'm changing inner and outer seals.
Old Sep 18, 2007 | 11:06 PM
TractorPacker's Avatar
Do you have a balloon?
<div class="FTQUOTE"><begin quote>Originally posted by: Red400EXRod
Yeah, I'm changing inner and outer seals.</end quote></div>
I have done it, didn't know you didn't know. Change the bearings, I didn't first try. After buying the second 32$$$ seal the bearing was sticky. I figure I hurt the bearing pulling it, to change that kicker cover.
Old Sep 19, 2007 | 11:27 AM
Pirate Biker
Limping Rider!
Didn't know your seals went bad. Just thought you broke the side case. I was able to tap the bearing out from the other side so I didn't put any pressure on the bearings themselves and I didn't even put a mark on the race. Bearing has no stick to it at all.
If they have a bearing in stock I'll get a new one but I don't have time to wait another week for it.
Customer Service #1
May 15, 2020 08:46 AM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Logan Collins
Sep 5, 2015 08:03 PM
